Is there a reason we can't parallel the new multiplus-ii 8 and 10k?
Thanks
Thanks
It would be nice to know if this is thought to be a permanent situation or if it is being worked on. It just seems so uncharacteristic of Victron to take a step backward in the development of a new product.
Hi @Phil Gavin
This is being worked on, for the products that are being produced now it is a limitation, feature hardware versions will have the possibility to be used in parallel but we don't know yet when these will be available.
Victron has many loyal customers. I would expect nothing less.
My information is that it is some kind of a hardware limitation.
Maybe there will be a solution sometime or maybe not.
Currently you only can use the "old" Quattro if you need that much power.
40 People are following this question.
