Alessio Guscetti avatar image
Alessio Guscetti asked
Multiplus II 24/3000/70-32 Smart Dongle problem
I have a problem with the smart dongle. When I connect via bluethoot to the inverter, the smart dongle is in secondary mode because it detects a colour control. But I do not have a colour control installed in the VE.Bus network.
Can someone help me?
Multiplus-II
The dongle always starts in secondary mode and will switch to primary mode after around 30sec if there is no GX device connected.
https://www.victronenergy.com/live/vebus_smart_dongle_manual#modes_of_operation
8 comments
Alessio Guscetti avatar image Alessio Guscetti commented ·
Right, I read the same thing, but it doesn't change mode even after a long time.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ Alessio Guscetti commented ·
Is there anything else connected to the VE.Bus or only the dongle?
Alessio Guscetti avatar image Alessio Guscetti Matthias Lange - DE ♦ commented ·
Only the dongle
Try to change the RJ45 cable and also try to use the other RJ45 port
Already tried, is there no possibility of resetting the Multiplus II? I think the problem is not with the dongle, but with the Multiplus.
I guess you already tried to switch the Multi OFF and ON.
To get access to the settings of the Multi you will need a MK3 Interface.
Is you Multi maybe one with an internal GX module?
Yes.
I also think that the only solution is a Color Control or an MK3.
No, it doesn't have a built-in GX.
Alessio Guscetti avatar image Alessio Guscetti Alessio Guscetti commented ·
Danke viel mal für deinem zeit, ich habe jetzt mit dem MK3 Usb was machen können.
Nun, ist mit der smart dongle immer das gleiches.
