robertfry avatar image
robertfry asked
Hub1, option 3
@alexandra
could you help or maybe recommend someone? been going a week now but the last 2 days system keeps battery state of charge around 52%. Doesn’t go any higher or fully charge batteries
Multiplus 24/3000/70
Mppt 150/70 tr
BMI 700
Cgx unit
I am connected to grid but don’t have a two way meter. Weather in uk pretty overcast at the moment so unit is only trying to send a few watts back to mains, showing on overview as -7, or -5 or no mains.
What will happen when gets sunnier this week and unit try’s to send more kw back to mains. Will it just go back to mains through the incoming, or is the unit just thinking it’s sending excess electric back when in fact it’s not.
To officially export back to grid, I need accreditation which is not possible for self install using second hand equipment.
Options 1 and 2 don’t fit my preference.
Option 4 is deprecated.
Can I just have option 3 but no excess back to grid?
Alexandra avatar image
Alexandra answered ·
@robertfry
Do I understand this correctly.
Your needs are: -
You want to keep batteries charged when connected to grid.
No feedback to grid.
Solar to aid consumption if connected to grid and it is sunny?
Hub 1 option three has a warning - it needs an anti-islanding device
(something like this one - https://www.victronenergy.com/accessories/ziehl-voltage-frequency-sensitive-relay-ufr1001e#manual)
Do you have a grid code set on the unit?
Would you prefer the unit disconnected entirely if it does not need the grid at all?
Other possible options are
https://community.victronenergy.com/storage/attachments/3299-virtual-switch-ignore-ac-lesson.pdf
https://www.victronenergy.com/live/assistants:ignore_ac_input_using_the_generator_assistant
Or using the CCGX relay with a contactor and the generator start stop progrmmable on the GX to connect and disconnect to the grid.
