toolsup avatar image
toolsup asked
Ripple Warning On Shore Power
I am having a problem that I don’t understand. When I am plugged into shore power and use a high drew item like the microwave (12.5amps) or air conditioner I am getting a low battery, battery voltage ripple, and sometimes an overload warning from the Victron App.
It’s strange because I don’t get any warnings when high draw items without shore power, everything seems to work fine when the power is coming from the batteries through the inverter.
At first, I thought maybe the shore power source may have not been providing 30amp’s and the inverter was kicking in to make up the difference. But it is happening anywhere I plug into a 30amp service.
Below is what I have installed.
4.00 BB10012 - Battle Born 12V 100Ah
Multiplus 12/3000/120-50 120v VE Bus
Victron BMV-712 Battery Monitor
Victron Lynx Distributor
VE.Bus Smart dongle
SmartSolar MPPT 100/50 Charge Controller with Bluetooth
toolsup answered ·
Problem solved. I got with Battle Born batteries and Brendon help me correct a few settings that weren't correct and now everything is working as expected.
Can you list those incorrect settings?
craig-pretzinger avatar image craig-pretzinger commented ·
Please let us know what the settings you used were? I have this same issue
