manib avatar image
manib asked
1 Victron battery balancer for 2 AGM batteries 12 Volt 260 Ampere connected in series
is it possible to use 2 AGM batteries (each 12 volts 260 amps) connected in series with a Victron battery balancer?
Or are the 2 x 260 amps already too much for the battery balancer?
Maybe you can help me here, thank you very much.
Manfred
victron
Alexandra avatar image
Alexandra answered ·
@ManiB
It should be fine. It will take a while as it draws up to 0.7A to do so. They can be paralleled to speed up the process.
https://www.victronenergy.com/upload/documents/Datasheet-Battery-Balancer-EN.pdf
http://bb-demo.victronenergy.com/
