jaaks avatar image
jaaks asked
DC\DC Charger wire size recommendations
Please could I have a bit of advise on the correct mm2 wire to use in the below.
I am installing a 30amp DC to DC charger in my trailer, the distance between the car battery (source) and charger is about 7m and the distance between the charger and the auxiliary battery is about 3m.
What size cable should I use for the 7m run?
What size cable should I use for the 3m run?
thanks
dc system
randy-putnam avatar image
randy-putnam answered ·
Check in the manual it shows you the proper cable size & fusing
