daryl avatar image
daryl asked
How to tell why system is dropping grid
The last couple of days my 3 phase multiplus II 5kva system has been deciding around 11am to disconnect from the grid and run off of battery/solar until around 4pm.
I presume the system is upset about grid voltage or something, but I can't actually spot any place inside the Cerbo GX that may indicate what it considers to be the problem.
As far as I can tell, the grid voltage on all phases is less than the overvoltage 10 minute average value configured in ve.config for each multiplus.
Multiplus-IIESS3 phase
Is the system connected to the internet?
If yes you could use the VRM portal to take a look at some diagrams maybe you can see there a voltage drop or something like that.
