destrvction avatar image
destrvction asked
Which Victron MPPT Settings for AGM battery?
I have just installed new Victron gear and im not sure what settings i should have for everything.
I have the Smart Shunt, Mppt 100/30 controller, Dc12/12/30 charger and the IP22 12/30 chager 3 ports.
I have 2 Ritar 120 AH AGM bateries connected for a 240AH total.
Which profile should i select for these batteries and are there any other settings i should change?
Thanks
setup
michelg avatar image
michelg answered ·
Hi Destrvction ! Hi will suggest to use the position 2, which seems to be fine for your needs !
Michel
destrvction avatar image destrvction commented ·
Thanks i will go with that then
