assaadeldleptany avatar image
assaadeldleptany asked
Multiplus 2 AC-1 breaker sizing
Hi everyone,
My house's load is 30A. I am installing a solar system and I am thinking of a Multiplus 2 3000VA which should be enough.
I want all my house to be connected to the critical load output, however I have few concerns below.
- If my load is 25 and PV's are supplying 20A, the grid when on will compensate the rest 5A needed. correct?
- What will happen if my load is 20A and suddenly the grid goes off? Knowing that the inverter output power is 11A (2400W), what will happen then?
Multiplus-II
Depending on you configuration the MultiPlus will take the 5A from the battery.
If there is no PV power availabe in that moment the MultiPlus will shut down due to overload.
assaadeldleptany avatar image assaadeldleptany commented ·
Many hanks Matthias.
One more question, can we setup the priorities to be:
1- PV
2- Grid
3- Batteries?
For example if load s 20 A and the PV are supplying 15A, can the rest be taken from the grid when available?
