jerothle avatar image
jerothle asked
Multiplus firmware-can't update
Multiplus firmware update.
I am using Victron Interface MK3 to USB (tried on 2 different computers, run as administrator and normal) Windows 10.
Port is autodetected for MK3.
Follow steps...
I have tried different patch cables.
Is this Multiplus not update-able?
I have tried 2702433 and 2702481. No success.
I have it connected to the Cerbo Gx on the VE.bus. I have read that it cannot be updated online through the Cerbo GX yet. The muliplus is working fine.
However, I also have the VE.bus Smart Dongle and it won't connect with firmware below 415.
I want to have multiple options for connecting to maintain the Multiplus.
I have read posts on this forum of successful firmware updates, but detailed steps were not given.
I have switched off... reconnected... tried both newer firmwares... 2 different windows 10 computers... different patch cables...
Is your Multiplus detected in VE.Configure 3?
Did you disconnected the inverter from Cerbo GX first?
Try to disconnect the Cerbo during the update.
pmikep avatar image
pmikep answered ·
I use VictronConnect to update the firmware on my Mulitiplus with my MK3 to USB.
lsi avatar image
lsi answered ·
I have the exact same need and problem and described my steps in great detail here; https://community.victronenergy.com/questions/92542/connection-error-while-updating-firmware-multiplus.html
Did you even manage to find the issue and resolve it?
Thanks!
tiamelis avatar image
tiamelis answered ·
Did someone managed to solve this connection problem ???
