jytkis avatar image
jytkis asked
Easysolar 24/3000 and ac input
Hi!
Should my easysolar wake up if I connect only ac input power from generator? At the moment I dont have batteries or solar panels connected and I want to test that everything is ok at the output devices, like lights and freezer.
Now I have connected input power but easysolar seems to be dead. I havent done anything else but connected input and outputs...
Generator
Alexandra avatar image
Alexandra answered ·
@Jytkis
An inverter by design needs to have a battery for reference in its system.
You really should have a bypass or change-over switch installed for such cases.
That being said it should be able to pass through the power in the on position, but have the internal charger disabled. Again not a recommended method of use.
And for obvious reasons you will have low battery warnings on the front of the unit.
jytkis avatar image
jytkis answered ·
Thanks!
I tried to look manuals to find an answer and I thought that I got defected unit. So next step is to connect batteries and solar panels.
