ripper avatar image
ripper asked
What does a Multiplus 12 800 do when a generator is present.
I am interested in the functionality which I havent quite understood.
I have a Honda EU 20 with 1800W max and a Multiplus 800.
On battery I can supply up to 800W ish with known limitations (temp and cos phi)
Now can I get the full generator power of 1800W via its transfer switch through the 800 unit?
Does it boost the 1800 W to plus 800W to 2.6 kW short term?
Is it shore power limit to limit to 1800W and then taking as much or as little as it can get to charge the batteries.
Is being shut off due to overload a problematic state of operation. You cant beat stupid and I m hoping it will just stop working if somebody tries his hair dryer and that is an obvious enough sign for the ignorant user.
Cheers guys
