jabrockert avatar image
jabrockert asked
multiplus just stopped switching over, and startup takes 1-2 minutes
My Multiplus 12/3000//120-50 has been installed for about 1 year and has just stopped switching over to battery. The power drops and the unit goes off and stays off. Once the power comes back on the Unit takes 1-2 minutes before the Unit even responds and comes on.
I've reviewed the forum's post's and ran a few checks as pointed out nothing out the the ordinary.
Seems there is some kind of log that I should be able to view. I've got a mk3-USB interface connected to a PC, but the settings require a password that I don't have. Not sure how to get to the log.
Any ideas where to go next ?
Joe
Check the Fuse between the Multi and battery.
jabrockert avatar image jabrockert commented ·
Yep, it's good. I've check all the way to the power on the board lug's. Even when the Unit goes off power is there.
Joe
Matthias Lange - DE avatar image Matthias Lange - DE ♦ jabrockert commented ·
What does VictronConnect show when the grid switches off?
Edit: somehow your other comment disappeared. But I guess the log is only useful for the developer.
jabrockert avatar image jabrockert Matthias Lange - DE ♦ commented ·
I switched it off and it didn't go off,...????? I've got some other problem, Need to end this thread for right now and get my installer out here
jabrockert answered ·
Ok, Figured out the log, is this usable?, Is there a program to run it thru?
Joe
