what equipment do i need (if any) to add to inverter charger and how to wire please?
looking to add 1000w solar panels plus 800ah lifep04 battery capacity
This is a question best directed to a dealer near you
https://www.victronenergy.com/where-to-buy
As it is fairly complicated one to answer over a forum. It would require an energy audit including peak loads and total daily consumption amongst other things. So depending on where you are installing this the 3000W system may not be enough.
42 People are following this question.
