hookem avatar image
hookem asked
Yet another Series-Parallel setup question: 6 * 100W panels on Sprinter RV
Seeking advice on optimal setup (6 * 100W on RV roof-top, taking shade into account)
Here are the specs on the 100W panels:
Voc = 25.4V, Vmp = 20.5V
Isc = 5.23A, Imp = 4.95A
Here are the options I'm considering so far:
1) 1 MPTT 100/50 Controller: 6 panels in Parallel.
2) 1 MPTT 100/50 Controller: 3 Sets of 2 Panels in Series, with the 3 Sets connected in Parallel
3) 1 MPTT 100/50 Controller: 2 Sets of 3 Panels in Series, with the 2 Sets connected in Parallel
4) 2 MPTT 100/30 Controllers: 2 Sets of 3 Panels in Parallel, with 1 Set per controller
5) 2 MPTT 100/30 Controllers: 2 Sets of 3 Panels in Series, with 1 Set per controller
6) 3 MPTT 100/20 Controllers: 3 Sets of 2 Panels in Parallel, with 1 Set per controller
7) 3 MPTT 100/20 Controllers: 3 Sets of 2 Panels in Series, with 1 Set per controller
==> 12V System: 2* 125Ah Li <==
Thanks in advance for your feedback.
setup
dazey77 avatar image
dazey77 answered ·
thoughts
1-No (too low voltage, too thick cable)
2-Perhaps, good shading resistance, good voltage (assuming 12v battery), medium cable thickness
3-perhaps, less shading resistance than 2, smaller cables
4-No (too low voltage
5-perhaps- having redundancy is nice and you could use a 100/20 rather than the 30.
6-3 seems overkill to me and if your doing 3 mppt, why not the 75/15
7-3 seems overkill to me and if your doing 3 mppt, why not the 75/15. Prefer this series option over 6 due to higher voltage
so 2 or 5 are my favourites.
(just to clarify, where I say too low voltage, its below optimal not won't work)
hookem avatar image hookem commented ·
Thanks for the feedback!
(*) #3 and #5 are similar (3 panels in Series per Set)
(*) #3 uses a single Controller for 2 Sets in Parallel
(*) #5 use separate Controllers per Set
wkirby avatar image
wkirby answered ·
Only piece of information missing here is the battery Voltage.
If 24V then option 1, 4 and 6 will not work at all.
If 12V then any of the options will work.
The best option to combat shading would be number 6, but it is the most costly, perhaps even OTT.
Option 4 is only slightly cheaper.
Option 1 would be good for shading and the most cost effective. Cabling becomes more expensive.
With more that two parallel strings or modules you'll do well to fuse each string before combining them.
12V system (Edited above). Thanks!
