jurjenhoekstra avatar image
jurjenhoekstra asked
PGN 127503 and 127504
Dear all,
I am struggling with the following: on my motoryacht I recently replaced a Czone 3.5 inch display with a Czone Touch 5 display. On the 3.5 inch display I can show the AC in and AC out of my Victron Quattro. The Czone display is part of a larger NMEA2000 network with various Czone modules (for digital switching) and several navigation equipment. My Victron GX is connected to the same NMEA2000 network. On the Simrad NSS 7 (and 12) chartplotter I can show the AC in (not the AC out). With software tools from Maretron and Actisense, I can see that the AC in and out information is available on the network and is published by the GX in PGN 65013, 65014 and 65016.
According to a Czone specialist Czone does not support PGN 65013-65016 and the information of AC in and AC out should be published through PGN 127503 and 127504.
It is strange that the Czone 3.5 inch display does show both AC in and AC out and that the Czone Touch 5 does not. Both are from the same brand Czone (by Bep Marine).
This has already cost me more then a week studying all manuals, websites and other available information, but I have not found a solution to show the AC in and AC out on the new display.
Is there a way to transfer or convert the AC in and AC out information from the PGN 65013, 65014 and 65016 to the PGN 127503 and 127504 so that possibly the Touch 5 will display the desired information.
Any help is appreciated!
NMEA 2000 - N2K
morganb avatar image morganb commented ·
Hi there
Did you get an answer to to this or solve somehow??? i have just run across the same issue
Thanks
Morgan
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ commented ·
Hi, I did a quick search, and found this:
https://www.nmea.org/Assets/nmea-2000-corrigendum-1-2010-1.pdf
Also, I know that NMEA2000-out function on our GX devices uses the J1939 style PGNs (which might be those 6xxxx numbers, no time to confirm that now). And that meanwhile there is a new set of PGNs.
So, could be that there are three (!) generations of N2K PGNs for AC information. And if thats the case than we are still in the second of those three.
hope this helps
morganb avatar image morganb mvader (Victron Energy) ♦♦ commented ·
Hi Mvader
Seems your correct
would there be any chance Victron would look to adapt the newer generation??
Its a shame as all the DC information works very well.
Thanks
Morgan
mattyroo avatar image
mattyroo answered ·
I have just had the exact same issue.
It seems that some manufacturers, Victron included, moved to the new AC PGNs of 65013- 65016, however, many manufacturers, CZone included, stayed with the legacy PGNs of 127503 and 127504. CZone will actually transmit the older PGNs of 127503 and 127504 as the new PGNs, if the "Transmit ALternate PGNs" box is ticked in the config, but it will not read them.
To get the AC PGNs from the Victron equipment as PGNs 127503 and 127504 on to your CZone network, you need to fit a Yacht Devices Bridge, YDNB-07 and have a program to write these from your specific device to the CZone network. Alexy Korolev at Yacht Devices assisted with our install and is very helpful. Please contact him.
4 comments
mattyroo avatar image mattyroo commented ·
@jurjenhoekstra see my answer above to your issue and how to resolve.
Show more comments
