johnny avatar image
current sensor without dipswitches - multiplus ii way off
Can someone please explain how it is suppose to work.
I have in assistant added current sensor.
In console i get a pv icon showing watts.
But its right now showing 2000w but its nothing in that phase now. evening and the sun is down.
If i unplug it it shows a value any way.
tried everything i can think of.
How it is suppose to work?
Multiplus-II
johnny avatar image
johnny answered ·
I sorted it out.
By putting the sensor in the temp in socket you just move the internal current sensor outside. I wanted to measure the pv current. I was doing it wrong.
I ordered the wrong current sensor i guess.
Paul B avatar image
Paul B answered ·
I presume you are using the victron AC current sensor but these have dipswitchs to set ???? and you have then added the assistant.
note that its a AC sensor not DC
if its connected correctly etc then it takes 24 hrs to calibrate itself
this is a bit of a guess as I am not sure what you are refering to really, if I am wrong then please post a diagram of your install and some more info in your description to fully explain what and how you are connecting it . even some pictures would be helpfull
