Michael Burr avatar image
Michael Burr asked
Can I use an Anderson Power end?
I have the IP67 charger. My batteries are 2 12 volt LiFePO connected in series. The connection uses Anderson power product ends. Can I put one of these ends on to the charger so I can just plug into my batteries when I need to charge them (one at a time). I don’t want to have to take my plugs off to screw done the charger every time.
Bluetooth
Kevin Windrem avatar image
Kevin Windrem answered ·
I don't see why you couldn't fit an Anderson connector to the charger.
Not sure this makes sense in your system but you could just leave the IP67 connected all the time.
Michael Burr avatar image Michael Burr commented ·
Thanks for the reply. This is used on a kayak so the charger will just stay at home. My batteries are connected in series with a product that uses the anderson power connectors. I just want to be able to quickly plug in the charger without removing the cables.
