jamesdew avatar image
jamesdew asked
Interface added information
Is it possible to modify the victron online interface so we can not only see how many volts the PV charger is delivering to the system, but also how much it could be potentially be delivering? Currently, if I want to see how much potential the weather conditions allow the panels to produce, I have to switch on everything in the house to see what they can deliver. If the mppts know how much they are throttling the supply from the PV, perhaps the potential power could be calculated?
CCGX Color Control
Kevin Windrem avatar image Kevin Windrem commented ·
As I understand it, an MPPT finds the maximum power transfer point by an educated trial an error. In the scenario you describe, there is no where to put energy for this algorithm to function. So I don't think it would be possible without providing a load to put on the controller's output.
