puppettalker avatar image
puppettalker asked
BMV current creeps up to 8A even when load disconnected
I just installed a BMV-712. When I first apply power to the BMV it shows 0.0A but after a while I came back and it was reading 7-8A, even with nothing on the load terminal.
Doing a zero current calibration makes no difference, it still shows 7-8A, but if I disconnect power and reconnect it starts out at 0A again, then makes it's way back up to 8A within a day.
I have nothing attached to the BMV except the negative battery terminal, power lead, and UTP cable. Nothing on the LOAD/CHARGER side at all, nothing is being moved or disturbed during this test.
Any thoughts? (I previously posted about this question but this is a new post with more info)
BMV Battery Monitor
How long does it take to get to 8A?
The BMV is connected to a Smart Network could you try to disconnect it from there?
If that changes nothing you should contact your dealer about a replacement.
puppettalker avatar image puppettalker commented ·
Thanks for chiming in. I'm not sure how long it takes, several hours or overnight. Once it goes up to 8A it seems to stay there indefinitely. Also "creep" was a poor choice of words in the original title. It seems to go from 0 to 7-8 with nothing in between. I come back the next day and it stays bouncing around 7-8A even after doing a zero current calibration.
I set up a Smart Network to share battery temp info with a Victron MPPT charger (although I have the temp lead disconnected from the BVM right now for troubleshooting). I will remove it for now.
EDIT: I shut off the Smart Network and still see the same behavior. Current goes back to 8A within a day. I added more screenshots to the original post.
klim8skeptic avatar image klim8skeptic ♦ puppettalker commented ·
Given you have removed the pcb from the shunt, that would be the first place to look.
The surfaces must be clean, and the screws tight.
puppettalker avatar image puppettalker klim8skeptic ♦ commented ·
You must've seen my other post. I did flip the PCB because it would've been a little easier to lay out the wiring that way but I flipped it back thinking maybe that was causing the problem. I checked for any debris and it is tightened very securely with the original screws and nothing else under them. I can reseat it a 3rd time but I really don't think it's the issue.
