One problem I see is the battery protect. These devices only work in one direction yet you have loads and charging sources on the same side of the battery protect. You need to split the positive distro buss into a "Loads" distro and a "Chargers" distro and connect each through a separate battery protect to the battery.
If the inverter is an inverter/charger current between it and the battery could flow both ways. I'm not certain how to address this without a BMS that talk to the inverter/charger.
27 People are following this question.
