ianjdodd avatar image
ianjdodd asked
BlueSolar 75/15 no load output on initial setup
Hello everyone.
I have just installed my BlueSolar 75/15 MPPT and am getting no load output whatsoever.
The battery voltage is 13.8V
The PV voltage is 27.6V
But load voltage is 0V
I have a steady amber light indicating 'float'
And a blinking green light indicating 'Batterylife' mode.
Does anyone have any idea as to why I'm not getting any load output please?
Many thanks
paul-w avatar image
paul-w answered ·
Have you been into the "Load" menu in the Victron Connect app to set the parameters for the load output to operate i.e. "Always on" "User def.algorithm" etc ?
ianjdodd avatar image ianjdodd commented ·
Hi, I don't have the Bluetooth version so I'm just going off the lights on the front of the unit.
paul-w avatar image paul-w ianjdodd commented ·
In that case then page 7 of the manual for your controller.
3.6 The load output (see figure 1 and 2 at the end of the manual) The VE.Direct communication port (see sect. 1.8) can be used to configure the load output. (dongle needed when using the Bluetooth app) Alternatively, a jumper can be used to to configure the load output as follows: ● No jumper: BatteryLife algorithm (see 1.4) ● Jumper between pin 1 and pin 2: conventional Low voltage load disconnect: 11,1V or 22,2V Automatic load reconnect: 13,1V or 26,2V ● Jumper between pin 2 and pin 3: conventional Low voltage load disconnect: 11,8V or 23,6V Automatic load reconnect: 14V or 28V
