cand avatar image
Multiplus auf dem Kopf gedreht einbauen ?
Hallo Community,
kann man einen Multiplus 12/1600/70 auf den Kopf gestellt einbauen (10cm Luft ist überall) ?
Viele Grüße
Cand
tozz avatar image
tozz answered ·
Short answer: Yes
Long answer: 'No'. The MultiPlus has a mounting bracket which you mount on the wall, then hang the MultiPlus on that bracket. If you would want to mount it upside down, it would fall of the bracket. You could do it if you would screw in the bottom (top in your case) screws before it falls down, but I wouldn't risk it. The MP is a heavy device., the bracket is there for a reason.
Additionally, the MultiPlus draws air from bottom to top. Hot air goes up, cold air goes down. If you hang it upside down you should probably turn the inside fan around as well, otherwise you will be blowing hot air down, which will float up again.
cand avatar image
cand answered ·
TX. Yours C
