paul-reading avatar image
paul-reading asked
MPPT with multiple source inputs?
I have a boat with three different areas planed to have solar. Each will be shaded at tie but with luck not all at the same time. Is there ever going to be a single MMPT controller that will handle multiple arrays instead of buying one MMPT controller for each array?
MPPT Controllers
myhomebuzz avatar image
myhomebuzz answered ·
A lot of information is missing: surface area, energy requirement, load capacity, type and capacity of batteries, distances between surfaces, type and power W of PV ...
Depending on the plan, it is possible to connect multiple PVs to an MPPT, but this depends on all of the factors listed above so that we can give you a clear answer.
