saullyman avatar image
saullyman asked
Ground relay is it necessary on auto-transformer
So i just installed a Victron Auto Transformer 32 amp version. I currently have a Multiplus 12/3000/120, I am feeding it to the autotransformer. This install is in my vehicle, the multiplus is grounded to the chassis, should I ground the autotransformer to the same chassis ground as the multiplus.
Or is it necessary to uncheck the ground relay setting in the multiplus. The picture i posted depicts the ground relay connection from the multiplus going to the earth relay on the autotransformer. Is this necessary.??
If it is necessary, where can I get 10mm long ferrules to connect to the 2 pin connectors.?? My standard 8mm ferrules are not long enough.
Grounding
Ground, earth and electrical safety
