Hello. I have a multiplus 12/3000 / 120 with version 2609158.VFDUsually I connect it to the PC through VEconfig and MK3 to USB to modify some specific data.Today I wanted to connect from a Tablet to make it more practical, since I use a tablet for other devices. Use OTG cable to connect. Multiplus was updated to version V481 (see photo) Nothing but that, it disconnected and does not reconnect. It is with Absorption, Bulk and Float LEDs flashing 1 time every second. From Veconfig I can see the real battery voltage as well as the network voltage. From Victronconnet I can also see DC voltage and Red voltage. From the CCGX if I connect it, I can also see those values and even turn off multiplus. From VeFlash I try to update again but I can't see the firmware file on my computer when I get to the photo I show. What I can do? Thanks.
Hola. Tengo un multiplus 12/3000 /120 con version 2609158.VFD
Habitualmente lo conecto al PC por medio de VEconfig y MK3 to USB para modificar algun dato puntual.
Hoy quise conectar desde Tablet para hacerlo mas practico, ya que uso tablet para otros dispositivos.
Use cable OTG para conectarme.
Multiplus se actualizo a version V481 ( ver foto)
Nada mas eso, se desconectĆ³ y no reconecta. EstĆ” con leds AbsorciĆ³n, Bulk y FlotaciĆ³n parpadeante 1 vez cada segundo.
Desde Veconfig puedo ver tension real de la bateria asi como la tension de red.
Desde Victronconnet tambiƩn puedo ver tension CC y tension Red.
Desde la CCGX si la conecto, tambien puedo ver esos valores e incluso apagar multiplus.
Desde VeFlash intento volver actualizar pero no consigo ver archivo firmware en ordenador cuando llego a la foto que muestro .
Que puedo hacer?
Gracias.
