hopeless-wanderer avatar image
hopeless-wanderer asked
Use of cytrix to join different kinds of battery for starting and potential winch use.
I am fitting out my vehicle for a remote expedition and will probably use Victron but have some questions.
The house batteries will be Lifepo4 (24 volt) and the battery to start the truck will be 24v (lead acid or AGM) I want the solar to charge the start battery once the house batteries are replenished and also want to be able to join the two battery banks together in an emergency to either start the vehicle if the starter battery is flat or to run the 24v winch if it's needed.
Is this possible and will the different battery chemistry cause issues.
starter battery
