hpzuidema avatar image
hpzuidema asked
Quattro from bulk not to absorbition/float. But to only inverter on
I have a Quattro that loads 2 lipo batteries on a greenline 40. It goes from bulk to only inverter on when on shore power.After bulk stops only the inverter on led burns. In the manual that is not a described state for the system. Is this a problem?
edvanz avatar image edvanz commented ·
If I recall well Greenline uses REC BMS maybe it is installed to cut the shorepower when 100% SOC is reached?
hpzuidema answered ·
How can i figure out that the shorepower is cut off when 100% soc is reached?
