I would like to start a generator using Relay 1 on the Maxi GX - is the Relay 1, potential free? Sorry probably quite obvious, just want to be sure.
Thanks
Thanks
How are you connecting the wires to Relay 1? Do you insert the wire into the bottom opening? are you using a ferrule?
GX - Generator auto start/stop
28 People are following this question.
