Tyler avatar image
VictronConnect Bulk State turns off Automatically
I have a 100 / 30 MPPT and I have three 200 watt solar panels attached and the bulk state turns off automatically.. I heard if the solar voltage goes below 5V higher than the Battery Voltage it automatically turns off.. why would this be the case? Why would the voltage drop and the bulk automatically turn off which stops my solar panels from charging. This doesn’t make any sense. If anyone can help me figure out how to fix this problem? Thank you
MPPT - Solar Charge Controller
klim8skeptic avatar image
klim8skeptic answered ·
It helps to read the Manual.
Your mppt will swap charging states as required automatically.
Tyler avatar image
Tyler answered ·
I read wire size wrong.. I saw 16 but that was 16mm and needs to be 6awg wire.
