Jeremy avatar image
Jeremy asked
Isolation transformer problem
I have a new isolation transformer that will not work. It is a 230v 3600 model. The input volt voltage is 245v the out put voltage is 0 with no leds lit on the panel or any other sign of life. Is there any tests that I can do with it before I return it. Thanks in advance
Isolation Tranformer
Kevin Windrem avatar image
Kevin Windrem answered ·
Make sure the internal jumpers are set correctly. The instructions in the manual suggest the jumpers might dot be preinstalled.
