geobyteman avatar image
geobyteman asked
BMV-712 connection to 6 6V Batteries
I installed 6 - 6V batteries in my RV, I added the BMV-712, and want to know if I can measure the midpoint voltage when they are wired 3 parallel sets of 2 in series for a 12 vdc system. I have included a connection diagram based on quick install guide that came with the BMV.RV Battery 6 x 6V with BMV-712.pdf thank you. George
BMV Battery Monitor
No, the midpoint voltage measuring is only designed to measure the midpoint voltage between 12V batteries in a 24V or 48v system.
https://www.victronenergy.com/media/pg/SmartShunt/en/midpoint-voltage-monitoring.html
