jake2664 avatar image
jake2664 asked
IP65/IP67 Blue Smart Charger Low Current Mode
I am researching the IP65 12/15 charger. I see a nominal charge current of 15A and a low current mode of 4A. If I manually trigger the low current mode and then unplug it completely from both supply and load, will it "remember" it is in low current mode next time it is used?
If not, I assume I can plug it in and then set it to low current prior to hooking up the battery and before drawing power? Once it is manually put in low current mode, will it remain in that mode until manually set to normal current?
I ask incase I find myself with limited available current and want to ensure I remain fully in the low current mode.
Thanks in advance!
battery charging
The charger will always continue with the last settings.
VictronConnect VE.Bus charging manual
