I have a 3 month old Multiplus 3000. It suddenly stopped inverting or charging. The green power light is on as is the yellow absorption light. Any ideas what has gone wrong and how to fix it?
How do you know it is not charging
If you use the Victron toolkit app you can check the definition of the led lights.
From what you have described the multi has mains and the bat teries are charging?
We would need more information to be able help you.
What position is the switch in? Do you have a mains connection. What batteries do you have? Are they ok?
38 People are following this question.
