Karl Fix avatar image
Karl Fix asked
I’m looking for a way to hard reset my SmartSolar MPPT 150/35
da0dff39-1b24-445d-b328-26af29d12f8c.jpeg5a53fdac-3e97-4920-8d39-8ff84699a92a.pngFrom one moment to an other the module does not let any current go by.
the panel side shows 40V. The battery side anything but far off the actual.
I did a Factory reset using the App. No change.
I disconnect the batteries as well as the panels. No change.
what els do you recommend to do/check?
MPPT Controllers
Have you had a really good look at the fuse/circuit breaker between the mppt and battery?
Your min battery voltage looks odd, and max batt voltage as well, plus no cumulative output.
phil-j avatar image
phil-j answered ·
Also having the same problem with a 75/15 !
trip-tracks avatar image
trip-tracks answered ·
The regulator is stuck on float.
Can you post some pics of the settings pages?
The absorption voltage seems pretty high. What type of batteries and configuration do you have?
