pateric avatar image
pateric asked
Can Multiplus ignore Temp from Smart Dongle
I have a 12/3000 Multiplus and I am using the Smart Dongle for remote control. I am unable to mount the dongle on the Battery for the temp sensor, but I have the Multiplus Temp sensor Connected to the battery and the Multiplus port.
The problem is, the Dongle seems to be overriding the temp sensor on the Multiplus. Is there any way to set this so that the Multiplus uses its own temp and ignores the Dongle?
Thank you in advance.
apl avatar image apl commented ·
I have the same question. Hopefully someone will be able to answer it.
