mdbrown avatar image
mdbrown asked
Smart Solar Output Current Limited by What?
Since the Smart Solar MPPTs can be set for a higher maximum output current than their ratings, what actually happens? Can a 50A MPPT be set at 60A, and put out 60A until it overheats and folds back?
smart solar charging behaviour
Lyndsay Cotton avatar image
Lyndsay Cotton answered ·
Could you advise where you read that they can be set higher.
Having just read the manual yesterday I did not find reference to that.
My understanding is that the smart Solar MPPT "clips" the input to a max of the rated current.
ie: a 250/85 will clip the output to 85A even if the output could be higher due to oversizing the array
This must be a bug in the demo library. I tested it with a real 150/60 and when you set the current higher than 60A it jumps back to 60A.
