tylera avatar image
tylera asked
Inverter inop after extended power-off
I returned to my boat after being laid up for the winter, and found that the Quattro inverter was no longer working.
Battery: 48V
AC-In-1: Unused
AC-In-2: Shore power
Things that work:
- Pass-through AC when Shore Power is on
- Battery charging
Things that don't work:
- Inverter (AC when on battery)
The Quattro was powered off for a long period of time over the winter (no power on the 48V battery, no AC-In from shore power). When I powered it back on, inverting seemed to no longer work.
I do have some control wires coming in on Aux-1 to control charging (not inverting). I removed all the Assistants from VE.Configure3, but all the parameters look correct.
At this point, I suspect hardware failure (my luck on this boat), but I wanted to make sure I haven't missed something obvious. What should I look for? What should I try?
I'm connected via VE.Bus to a CCGX then on to a Digital MultiControl.
It is interesting that the CCGX reports things on AC-In L1 (there is nothing physically connected there, but there are things on AC-In L2, this could just be a CCGX bug)
I am using Valence batteries, so I do not have a Victron BMS. However, the 48V is present so I'd just expect inverting to work. When I do have the Assistant in place*, the CCGX has a "VE.Bus BMS" subpage under the quattro showing "Allow to discharge" as "yes" (which would indicate that inverting should be allowed.
* Configured as two-signal BMS support / BMS has one contact with switches only on a high-cell condition / aux-1; open / force to float; SOC to 100.
[I suspect, but I haven't verified this, that the Quattro only charged the Lithium battery at 54V (the float voltage) instead of trying to push the higher voltage. Unfortunately, I was busy investigating other things, but the Quattro stopped charging when the Valence BMS indicated 67% SOC. I'll go back to the boat tomorrow for more investigation.]
@TylerA
For a quattro to 'recover' from a low battery you need to use ac1 in for it to self recover. The system does not 'wake up' using ac2
What did your investigation on the boat turn up?
tylera avatar image tylera Alexandra ♦ commented ·
While the charge was initially low, I slowly charged with solar over a week before getting shore power on anyway. That is good to know about AC-2 vs AC-1.
Sadly, Oceanvolt remoted into the boat (I'm displeased with this) without telling me exactly what happened/changed, so I have nothing to report. It just works* now.
* Almost. But beyond the scope of this question.
I guess I'll close this with no answer.
