handsy avatar image
handsy asked
RCD Protection With Multiplus In Motorhome
We have a 24v Multiplus 5000va and its goin into a motorhome. My questions are the following:
  • Does the Multiplus require an RCD before the input from hookup? If it does will this be an RCD, RCBO or RCD & MCB etc? Also I assume that as the Multiplus input current can be adjusted, if it does require an RCD shall I put a 16A RCD and set the Multiplus to 16A alo as most campsites are 16A?
  • After the Multiplus again what protection avriant is required, i.e RCD them MCBs, or RCBOs? I understand they need to be double pole and C rated, is this correct?
Thanks Dan
