Henning Schneider avatar image
Henning Schneider asked
timer driven output on AC2
Good Day,
I am using AC2 output on a Quattro for the water heater (excess energy dump from the wind generators). However, I like to trigger this output with a momentary switch (for i.E.15min) by using one of the digital inputs. Is this possible, since I have not seen any timers for the outputs in any assistant so far.
MPPT Controllers
Not 100% sure but I think this should work:
This will close the AC OUT 2 relay immediately if a push button at AUX 1 is pushed and open the relay after 900 seconds (15min).
