Caspar Ebner avatar image
Caspar Ebner asked
Getting current voltage with VE.Can
Hi all.
Im looking into getting the curent voltage or any momentary information on the VE.Can.
I already looked into the VE.Can registers public pdf and looked through a lot of questions here. I did not find annything on this.
My settup consist of a Lynx Shunt VE.Can a Venus GX and a Smart Shunt (I am just testing at the moment).
So far i am able to reach the registers for the historic values however it would make my work a lot easier to get values such as momentary Voltage, current and consumed Ah since i am looking into integrating these Values into another system via a Can Bus connection.
Are there any registers that would give me these informations?
Thanks
VE.Can
Ulrich avatar image
Ulrich answered ·
I'm not sure I understand the question correctly. Is it about values that can be seen in the Victron Connect app?
There is a description of all the values to be queried here: https://github.com/victronenergy/venus/wiki/dbus
Does that help you further? Here I have shown these values with the help of Grafana: https://www.zoomsoft.de/grafana
I hope I was able to help you, if not then I did not understand the question - please excuse me.
Caspar Ebner avatar image Caspar Ebner commented ·
No worries but thank you for your answer!
I am looking to get these Values with the NMEA2000 out function on the VE.Can and read them with a Microcontroller. Thus far I am able to get the historic values and consumed Ah with a bus monitor. My problem with this is, I do find the NMEA2000 PGN for Battery-Status which would be 0x1F214 or dec 127508, but I do not know how to handle these any further with a bus monitor, or I have to switch my plans completely to NMEA2000.
