dreamagic avatar image
dreamagic asked
MPPT 100/30 will not switch on
I have an MPPT 100/30 with a Bluetooth dongle. It has worked perfectly for 18 months. Recently I disconnected and reconnected the solar panels but now the controller sits in the off position.
I have tested the connections and get 57v at the wires to the PV. But when I connect the wires if I put a multimeter across the PV terminals there is no reading.
The blue LED blinks every 4 seconds or so.
MPPT Controllers
Sounds like reverse polarity PV connection. Please check.
A bad connection on the PV wiring gives similar results.. check.
dreamagic avatar image dreamagic klim8skeptic ♦ commented ·
Thank you.
Paul B avatar image
Paul B answered ·
answered as per comments by klim6skeptic
