myrkr avatar image
myrkr asked
Multiplus 24/3000/70-50 (Watts - Temp - Time Chart) + Circuit Breaker Sizing
Hello, I've been searching and reading through various threads trying to find information on this topic but am only finding bits and pieces. I'm trying figure out two things
  1. Is there some kind of chart somewhere that gives rough approximation of the inverter wattage over the continuous rating (2400 @25c), and how long that wattage is available? I see the 6000 watts peak, but assume there must be some kind of algorithm for the amount of wattage over continuous available for a certain duration (ie @25c 3000 for 8 mins, 3600 for 6 mins, 4200 for 4 mins, etc.)
  2. In terms of sizing the AC-OUT-1, for the main circuit breaker I see the manual shows 50+13 amps if using Power Assist, but assuming I'm not going to use power assist can I just use a 50 amp main breaker for my AC distribution panel? Of course assuming I'll use the correct size wire for the load.
Thanks
MPPT ControllersMultiPlus Quattro Inverter Charger
