nightryder7 avatar image
nightryder7 asked
Super Cycle Smart Shunt Settings Advice
Hello there,
I have recently purchased a Victron 230Ah Super Cycle AGM battery and hooked it up to a Victron Smart Shunt. I am wondering what settings are best in the app for the shunt. Any advice would be helpful.
From what I have learnt from the Victron advice video:
Battery capacity: This is set correctly to 230Ah
Charged voltage: This should be set to the "float charge" voltage as per the Super Cycle data sheet which is 13.5-13.8V minus 0.2V (for all 12V batteries). So, it should be set to 13.3V - correct?
Discharge floor: 50% is correct for a AGM
Tail current: Is okay to remain at 4%
Charge efficiency factor: Since, I will be discharging this battery mostly to about 80% or so most of the time. As per the mentioned above video should be changed to between 80-85%.
Any other settings seem to be fine to keep as they are.
What do you think? (current settings in pic below)
SmartShuntAGM Battery
