Can a 3phase multiplus system accept as Input a 3phase generator without neutral (only L1, L2, L3) (Delta).
Hello, No, as the units are essential 230Vac (or 120Vac depending on the area) the input needs to match this. When the input is 3p without a N there is no correct voltage reference per unit so it will not be accepted.
Thank you very much for your answer, that was what we expected.
5 People are following this question.
