bernardgarrett avatar image
bernardgarrett asked
Max Solar Panel wattage for a MPPT Controller
Hello Everyone
Newbie to Victron and Solar stuff. (So please be kind)
Using the MPPT Calculator it seems that the Maximum Power input from the 360Watt panels( 9X360)=3240w. Does that mean I have to purchase a Solar Charge Controller (Smart Solar 250/100) for every 3240w of panels.?
If I am missing something in my logic please educate me.
Thank you
MPPT Controllers
seb71 avatar image
seb71 answered ·
Start from the solar chargers datasheets.
bernardgarrett avatar image bernardgarrett commented ·
I have done so. My research shows that I can only have 9 panels and they would (theoretically) generate 3240 watts.
Again, A, I missing something?
Thank you
seb71 avatar image seb71 bernardgarrett commented ·
The maximum PV array power depends on the battery voltage. You did not indicate this.
Voc is also important, etc.
bernardgarrett answered ·
So having done the sums on Voltage / Current, etc. it seems that 9 360W Panels is my maximum.
Let me rephrase my question. Is anybody able to generate more than the theoretical 3240W from one Solar Charge Controller?
Yes. 5800W.
dazey77 avatar image
dazey77 answered ·
the maximium power out of a victron charge controller is set by the output current x charging voltage.
Take a 75/15, it has a max output current of 15A. Its maximum output power will depend on battery voltages and the point in the charge cycle. Lithium have a higher voltage so the controller can put out a slightly higher power. Obviously the max power will vary across the charge cycle as the bat voltage goes up and down.
250/100 @ 12v (lets say 13v in a bulk charge)= 1300w, 1400w towards end of its charge. Double power with 24v, quad with 48v
