Connection looks ok to me. Are you using an alternative shunt or the Victron standard one? Do you have settings 65 (Shunt Current) and 66 (Shunt Voltage) set per the shunt you are using? I am interested in doing the same as you and also using the relay to achieve a target SOC for Lithium battery storage.
29 People are following this question.
