segeberger avatar image
segeberger asked
REC BMS parallel with Pylontech US2000
I am using Pylontech US2000 in my set-up. The Pylontech are set-up for DVCC and controling the system. All fine.
No I want to use the REC BMS in parallel for my LiFePo4 batteries and for monitoring the general data from the battery. It is not planed/ needed to control the charger that is done by Pylontech.
Is that possible and if yes, what should I set-up in the menu from REC BMS?
If I connect the REC to VECan from CCGX, nothing is shown in CCGX.
My set-up:
CCGX
MP2
150/100 MPPT
Pylontech as "main battery and BMS"
BMS
