matthieujacobs13 avatar image
matthieujacobs13 asked
Setting different SOC depending on AC input available
For an installation with a 48V-5kVA quattro and backup generator, I was wondering if it is possible to set a different minimum SOC for the battery depending on the AC input available. For example in case of a grid outage I want to preferentially discharge the battery for critical loads, but if the generator is available I also want to power the second AC output using power from the generator
ESSGenerator
Kevin Windrem avatar image
Kevin Windrem answered ·
Without ESS the system will attempt to keep SOC at 100% if grid is present. You can set the generator to start and stop at user-defined SOC thresholds.
With ESS, you can also set SOC thresholds for using grid power.
matthieujacobs13 avatar image matthieujacobs13 commented ·
Thanks for the answer, I understand this, but the issue is that the battery isn't powerful enough for all the loads (critical + aux) and if the generator is available I want to be able to power the auxiliary loads, but use more battery capacity than with the main grid available to reduce fuel cost and emissions
