I can not get more than 13,3A output from my MPPT 100/15 towards the battery. I tried it with AGM and LiFePo4 also. It stays stabel at 13,3A.
My 100/20 can push 20A without a problem...
Is it normal or a defekt?
Thank You,
UbiHello,
Thank You,
UbiSome specifications about your panel, and battery details would be helpful.
I have several 330W and 405W Panels, I have tried it with serial and paralell setting also. The AGM was 24V(2x12V) 100Ah, the LiFePo4 is 24V 560Ah. Together with the 100/20 the batteries can absorb more than 13,3A. I have tried it.
So, there must be something with the 100/15...
43 People are following this question.
